Need Help chosing a case.
6 Mar 2007
SW London
Ok I cant decide what case to go for, upto now i had pretty much settled on a P182, but i have been looking at some of the silverstones (TJ09 particularly) and realy like the look of them. Now my main concern is that my house is VERY VERY dusty, i mean if i dont clean out my pc every month or so, problems start. So straight away P182 has an advantage with the dust filters, but what are my other options?:confused::confused:
dont worry about dust filters as they are quite easy to make (just attach tights over holes where dust can enter) or buy. you should be more concerned about the size of the case, build quality and its looks (in my opinion).
if you want a suggestion i say go with a v1000 or v2000, i have the v2000 and thats the v1000s bigger brother. in my opinion, its a very good case with no problems when it comes to space.
