Need help chosing a new case
10 Jan 2006
Reading
I am currently using an Eclipse to house my hardware. CPU cooling is taken care of via a PA 240 mounted on the back of the case using a Swiftech rad box.
I am looking to replace the case and have the rad mounted internally in the case with the pump and other components.I like the look and price of the silverstone FT01B and TL07B cases and have studied the various threads about them.
I don't really want to spend additional money on new rads etc or indeed hacking the newly acquired case to suit.
Any other suggestions for an internally water cooled case that will be quiet around £200 ?
Thanks Matt
Lian Li A70 and especially door equipped A71 have very silencing friendly features (very good after installing damping mats) and could easily take radiator to top.
If doing modding doesn't sound good Lian Li has also top panels with ready holes:
http://www.lian-li.com.tw/v2/en/product/product04.php?cl_index=2&sc_index=10&ss_index=74
Silverstone TJ07 has hard HDD mounting so their resonances will be all over the place and overal design really isn't silencing friendly.
FT01 is lot crampier and neither it has much better silencing feature set, while there's at least some rubber washers plastic trays aren't good thing and with HDDs in place forcing airflow through that about fully blocked dense packed HDD cage needs lot of pressure/fan RPM.
Also these need mass loading of panels with damping mats. (sidepanels are alway sensitive for resonances and especially in case of lighter aluminum)
Hei EsaT, Thanks for the suggestions. I am running a couple of velociraptors so HD silencing must be reasonable. I like the look of the A71 and will consider it.
I have just returned from a skiing holiday from Finland, Yllas. Fantastic country, with great people.
Matt
HD seek noises are one area where quiet case design helps lot.
HDD itself radiates noises so plain soft mounting isn't enough for making them really quiet, that's why damped panels with indirect noise escape paths are pretty much mandatory for really quiet PC. Same things also lower noise of graphic card and other noises created by components.
That's also why Antec P180 is so quiet even with higher end parts.
But Antec P180 is just cramped case with little device bays so it was out of my consideration when damped CM Stacker T01 with noise leaks in front started sounding too noisy. After something like three month active (+2 months less active) studying I ended up to A71 and although aluminum is acoustically worser than steel there just aren't any other cases with even closely as good combination of space, easy access to all components inside case and silencing friendly feature set.
Knowing that vibration problems when taking case out from packet weren't that big surprise and is probably common problem with aluminum cases. Little loosely attached top edges of side panels definitely don't help in that but after adding damping mat that rattling disappeared totally and mat also increased rigidity of panels.
Here's pic of it during building, shows well how efficiently design uses space for lot of device bays still leaving plenty of space for accessing everything.
HDD cage itself vibrates slightly (can be felt) but with generously damped case that slight vibration coming through rubber washers doesn't cause any noise and lack of direct noise escape path further dampens HDD/fan noises.
So despite of acoustically worser material aluminum case can be made very quiet and light weight actually turned to nice advantage: Case itself weights only ~9kg which rose to ~12kg with damping leaving final weight lot lower than similar size steel cases with even lacking features. Already aluminum sided Stacker weights 14kg (same as Antec P180) without anything and 16kg with damping and was still lot noisier because of acoustically bad design/features.
With that good results achieved from quiet design with damping I'm now preferring not to waste weight for heavier case and wouldn't even anymore think about getting steel case.
(also doors of Lian Lis can be changed to open in either direction)
And that piece of acoustically near useless Akasa mat is there only because I wanted to leave more air space around PSU, other mats are actual damping mat: that smoot dark mat is current BeQuiet Noise Absorber (BGZ14) while that piece below motherboard and smaller strips of it better visible in big picture are older 3mm thinner version of it.
Recent snow in UK probably now doesn't feel as such big deal.
Next time try northern Finland near christmas... you won't be bothered by sun because it doesn't rise at all...
(or at summer there'll be long wait if you wait for sunset to go sleeping)
