Hi there , by default fullscreen is set to yes in cod waw , you can change this by editing the line:
seta r_fullscreen "1" to seta r_fullscreen "0"
but to do this you need to close the game and edit the cfg
is there a way to bind buttons so while im playing i can press a button to go from fullscreen to half screen (to use admin rcon) then back to full screen ?
see if i simply use alt-tab or ctr-alt-del my game crashes,then i thought about the binds ppl use for FOV 80 and wondered if it would work for changing screen size ?
it will make admining my server a lot easier
can any one shed any light on how to do this ?
