Its a 9800GTX+
It recommends:
Question is:
Do I connect just one of these PCI-E power cables:
Or do I use the adapter they provided and connect two of these 4 pin peripheral:
Even easier explanation:
PSU I bought has these specs
Which one?
Thanks in advance! (Ive never had a card that needs any power other than from the mobo - dont want to screw this up)
It recommends:
(note that my actual card has only one slot for the PCI-E power cable [see pic] so I understand that I need TWO available HD power connectors (by which they mean the 4 pin peripheral cable right?))-450 Watt or greater PSU with a minimum of 24 amps on the +12Volt rail
Two 6 pin PCI Express power connectors or four available hard disk power connectors
Question is:
Which one?
