- 2 Aug 2014
- Watford
As title says is it safe to boot the pc, like this.
What could i put ?
actually very bad idea to use the outside of an anti static bag
Exactly!There's not only electrical safety to consider but also vibration.
How comes you havent water cooled the CPU, looks like you've got some custom water on the GPU so i'm not sure why you wouldnt add the CPU to the loop and use a much smaller waterblock to cool it.
Move it down a slot if I were you, as long as you have another available 16x there is no downside.
Exactly!
Combined to the often ilttle pointy bits sticking out of the solder on the back of PCBs, whatever is used to insulate between them and cooler needs to be structurally able to keep those pointy bits from being able to poke through and short out on cooler.![]()
