Need help creating an editable table in ASP.Net
6 Jan 2006
Midlands
Hi!
I need help getting started with creating an editable table.
I need a create a table and allow the user to type in the table cells. Once the user has finished editing the table, i need to go through each cell and store any data into the database.
How do i go about doing that? What control shall i use!
any advice would be great, abit stuck on where to start at the moment.
thanks
You could use a datagrid control?
e.g ASP.Net Kick Start (Pub. SAMS) book by Stephen Walther.
Mel P
with a datagrid control i need to bind a datasource to create a table? Anyhow all i need is an empty table and then i wanna go through each cell.
