- 23 Sep 2020
Hi there.
I am looking to get an ultrawide monitor, I will be saving up so anywhere between £200 and £400, the cheaper the better haha. I will be using it for productivity. I will be getting a gaming monitor later on that has 144hz or something similar.
I currently have a 2600x with a 1060 6GB GPU. I will upgrade the GPU middle of 2021, it is a new PC I built 2 weeks ago.
Would it be good to go for a 1440p ultrawide with 144hz, I found a iiyama G-Master GB3461WQSU-B1 for £399.99 that is 3440 by 1440 with 1ms response time and 144 Hz. Would this be ideal?
I would be getting a gaming monitor that's 27" and the ultrawide would be 34".
Any advice would be great.
P.S. I am a cyber Security student so the ultrawide is so I can have several things open and visible at once and I would also use it when I am streaming. I currently have 2 1080p 60Hz 27" Monitors that I am using until I get an ultrawide.
