My mate's PC loads a blue background, no explorer or anything loads up.
If he presses Ctrl+Alt+Del and brings Run up from the Task Manager, he could type Firefox and it would load his browser, but when you type explorer.exe it would say it cannot be found.
He is a gamer so only wants his game to load, which is does if you type the path in the run command, but he moved his PC to another room and now cannot connect to the internet wirelessly.
He needs to load up the network connections but I cannot find the run command for it. He is using Windows XP.
Please can someone help?
Thanks in advance
Thanks in advance
