Need help figuring out what I need to upgrade for my computer.
30 Nov 2019
Hello everybody, so my computer is about 7-8 years old and I have upgraded a few parts over the years but I need some recommendations from people more experienced than me on what parts could be slowing my computer down and what needs to be upgraded first! Here are my specs: tell me if you need anymore information.
[UserBenchmarks: Game 49%, Desk 51%, Work 30%](https://www.userbenchmark.com/UserRun/22170491)
||Model|Bench
**CPU**|[Intel Core i5-4690K](https://cpu.userbenchmark.com/Intel-Core-i5-4690K/Rating/2432)|68.2%
**GPU**|[Nvidia GTX 1060-6GB](https://gpu.userbenchmark.com/Nvidia-GTX-1060-6GB/Rating/3639)|52.7%
**SSD**|[Samsung 850 Evo 120GB](https://ssd.userbenchmark.com/Samsung-850-Evo-120GB/Rating/3484)|87.2%
**HDD**|[WD Blue 250GB (2010)](https://hdd.userbenchmark.com/SpeedTest/53/WDC-WD2500AAKX-753CA1)|11.7%
**HDD**|[WD Blue 1TB (2012)](https://hdd.userbenchmark.com/WD-Blue-1TB-2012/Rating/1779)|56%
**RAM**|[Corsair Vengeance DDR3 1866 C10 1x8GB](https://ram.userbenchmark.com/SpeedTest/95762/Corsair-Vengeance-CMZ8GX3M1A1866C10-1x8GB)|24.3%
**MBD**|[Asus MAXIMUS VI HERO](https://www.userbenchmark.com/System/Asus-MAXIMUS-VI-HERO/72)|
What is your budget? Have you Overclocked your CPU to gain more performance? Are you currently having any issues when gaming etc?
Hello Minibiker, appreciate your response.
My budget right now is 300-400. So not too much for enough for a part or two I'd say. I have not overclocked my CPU yet ever. The main issues I have with gaming is that I can't run many games. Extremely low frame rate. Booting up my computer also takes a long time and freezes when I have more than one program running.
The slow start up and response times could be the fact that you have HDD, If you can grab a nice 500gb SSD and do a fresh Windows install and have games on that youll see a big difference... If your willing to spend money and would rather have better performance out the box instead of needing to overclock your CPU then I'd consider moving to DDR4 and Ryzen
Hello Minibiker,
I am fine with spending some time figuring out how to overclock my current processor. I am guessing that DDR4 is just a more modern and better version of current RAM cards? I apologize I might be a little confused here. My budget is like 300-350 actually really so I can't go too deep. think I am just gonna opt for getting a new SSD and some more RAM. I am also guessing that Ryzen is another manufacturer of processing chips? I have heard in another forum that AMD has become very good lately as well.
If the 128 ssd is the os drive it is too full at 87%. A bigger ssd will do wonders. 8Gb if ram is absolute minimum, upping to 16Gb will also help. Any left over budget should go to a faster gpu, maybe a 2070 super.
Andi.
You are right andi. My 250GB drive is actually the OS drive which could explain why it's so slow. I think I am going to buy some new RAM and another SSD but then what would I replace? I imagine I would transfer all the contents of my 250 HDD to my new SSD as well as keeping my 1TB hard drive and 120 GB solid state? Or can you only have one solid state? Thanks for your help.
Also, once I get new SSD and more RAM I think the next goal is a new processor then. Thoughts on whats the best right now or who makes the best product? I have heard lately that AMD makes very good stuff. Is my graphics card okay too? Would that need to be upgraded if its only 6GB?
Thanks.
I forgot to ask, what PSU do you have?
My basket at Overclockers UK:
Total: £338.47 (includes shipping: £10.50)
^^ that's what I'd consider, if you can push for a 500gb SSD for around £60 then go for it
Before I crack open my computer case, what do you need the PSU for? Are those parts you listed such as the DDR and processor dependent on if I have sufficient power supply?
@Toby Exner only reason it's good to ask what your PSU is like age and watts is because if you add a new GPU or Overclock your CPU it will draw more power from your PSU, you don't want to be doing any of that until you know your PSU is strong enough...
As for your question about Ryzen, it's AMD range and over the past couple of years has caught up with Intel and in some areas beat it....
Good point Minibiker. I have wanted to overclock my CPU for awhile so while I am putting in upgrades it might be good to look into overclocking. My PSU is the Corsair CX600.
I also had another question regarding RAM. Should I replace my 8GB stick and get 2X8GB sticks or should I just add one stick that rounds out to 16GB? Will there be a problem if I have mismatched rams and one is DDR3 while another is DDR4? My system information says ASUS: All Series and I have a maximus vi hero so I assume my computer can handle any ram yes? I was looking at this one
RAM competitor link removed
and this one
SSD competitor link removed
And then I am going to monitor these changes, try to overclock my CPU and measure results. Thoughts on those two pieces of equipment?
