Need help filling loop
3 Aug 2010
I bought the OcUK V12 ULTIMATE Watercooled Case - Xigmatek Elysium. This is my first time watercooling so I thought i would buy the pre-made case, but I was going to add two 580's to the loop and got overclockers to customise the case a bit by adding another 240 rad to the loop.
So the case arrived, i blocked the 580's myself and added them to the loop. So I started filling the loop, got some water in, tilted the case side to side a bit to get more water in. Turned pump on and then off every now and then but more water didn't seem to get round the loop.
So i checked the direction the loop was going and noticed that they have attached the tube going from the 240 rad to the INLET of the pump top, then the OUTLET of the pump top goes up to the OUTLET of the Res. !!
Anyone got any ideas ? and is this bad the way it is set up. From what i've read you should always go Res to Pump first.
Also I found someones from OCUK 1 month notice letter in the res box :S
