Need help finding a cable to get my fans working
9 Dec 2009
Manchester
Hey guys
I have a bit of a problem. I was sitting at my desk with my feet resting on the desk and against my computer which sits ontop of the desk. I applied too much pressure on the hinged door on my case (Lian Li P80 armoursuit) and the door came flying off. The door seems tobe in great shape however the fan cable seemed to have snapped straight off. As the door has 3 fans embedded onto the door to supply fresh air to my radiator in the 5.25 inch bays I need them to work. The 3 fans on the door connect to a little hub box in the door and then a 3 pin female cable runs from the hub all the way to my fan aquaero fan controller which again only accepts a female connection. I have tried googling etc but everywhere just seems to sell the 3 pin fan extension cables of the male to female variaety. I unfortunately need a 3 pin female to female connection. Does anyone know if there are any for sale or know of anything I can do as to remedy this please.
I've just had quick search and come up with nothing sadly.
If no-one else can find one, I have one I made myself here that I'm not using.
Send me some details in Trust and I'll post it out to you.
It's about 400mm unbraided.
Bit blurry, my phone cam sucks in un-natural light
