Need help finding a Monitor stand/mount!
24 Jul 2012
Hi guys,
I'm looking to buy a monitor stand/mount for my 2 screen setup, I would like my monitors to remain horizontal with one monitor above the other.
Can you recommend a reasonably priced stand/mount that can achieve this as this is a new area for me exploration for me!
Thanks and regards!
(sorry if this is the wrong section, monitors seemed to be the most appropriate!)
Well damn, I hadn't thought of that.....just check and one of the monitors doesn't have a vesa mount whilst the other does =/ a single monitor mount would also work as it's the Vesa Monitor I want above my main monitor!
Sadly I can't mount to the wall :P aha but C35799Gamble your suggestion interests me! any specific model of mount you recommend?
[also that's a rather sexy setup you have....]
