need help finding a quality lappy that weighs under 2kg
4 Feb 2003
telford, shropshire
got a mate trying to get hold of a laptop, problem is hes in the army, stationed and cannot get delivery.
from what i;ve been told he can get a delivery from the army if the package is 2kg or UNDER anyone know if there are any decent/quality laptops for that weight ?
cheers.......
Trouble is - the average weight of a laptop is around the 2Kg mark, the fact that you will have to package it up very well will mean you have much less.
Why dont you get a customizable laptop and take the parts out and send them boxed separately. It will remove a lot of weight.
Just taking out the battery and hard drive would be enougth on most, its a good suggestion.
Theres a new Toshiba that weighs less than 2KG, 2 secs ill find the model number.
Edit:TOSHIBA SATLTE U300-11V
