Need Help Finding Graphic Please...
3 Mar 2008
Cornwall
Hey Guys,
Trying to find a vector (.eps) image of this:
Need to be able to use it to cut some vinyl, any ECG trace as long as its very similar to the one above would be great. This (the one above) is the only one I have but its not suitable to use as it has loads of jaggy edges which the plotter tried to cut. :confused:
Maybe if someone can convert the original then that would be ace, can be found here: http://www.quad-response.com/images/ecg.psd 1.39mb/2138 x 1358
Any help would be gratefully received, Thanks In Advance.
AP
