Need help finding switches please!
21 Feb 2006
Home
Hey guys, my googlfu is failing me!
I'm looking for these switches;
iQPkpmu.jpgs
They large switches with a screwless face plate that is 12cmx12cm.
I am struggling trying to find these sorts of wall switches.
Anyone have any ideas?
Thanks
Might be useful if you said why you're looking for them, ie need a new switch to match, that one's faulty, just like screwless plate etc. Only because it might make an alternative viable (replacing a switch is very easy fyi).
Need to replace as it's faulty. The rest of the house has all these switches installed so would rather try source the same, otherwise I'd have to replace the lot, unless I can find a decent alternative.
It just puzzles me how I cannot even find them, very weird as I don't even know if they came as a set or they were all bought separate and put together.
Can't even find the face plates?
