Hi
After getting the prodigy i found that my XFX PSU if far to long thus needs to go and be replaced with something that can do its job but at a much shorter length
I'm after a Power supply that will do the following:
My Specs if it will help:
i7 3770k @ 4.6Ghz
16Gb DDR3
Asus P8Z77-I
Asus 7970 DCII @ 1200/1800
2x 2.5" 1TB HDD's
1x 128Gb SSD
I'm hoping to get a 7990 in the future, so if you can help me find a psu that will also be up to powering a dual card if need be.
Please help me find this PSU!
- Fit in a bitfenix prodigy
- Fully Modular
- Have the Hybrid fan switch that allows the fan to turn off unless required (much the the XFX Black edition Pro 1KW Platinum Has)
- Enough wattage for that will allow a dual core card to be used in future.
i7 3770k @ 4.6Ghz
16Gb DDR3
Asus P8Z77-I
2x 2.5" 1TB HDD's
1x 128Gb SSD
