It could be, although its possible the blue is an earth, the yellow is a live for the rear tail lamp and the yellow/green is a live for the switched brake light. The all operate from the same bulb, unless its an LED setup of course.Bug One said:...and the yellow and green is equivalent to orange.
I can't see how you could do anything to damage it. They all work off the same voltage, so the worst that will happen is the lights will be the wrong way round.Trixter said:So i get it wrong its not gonna do any damage is it ? I mean if its wrong the light will just stay on without pressing the brake ?
Will eat some food then go and have a look.
