Need help for finding monitors for 3 screen set up.
9 Oct 2012
Hi guys i was just wondering if there is a good monitor i could get for a 3 screen gaming setup. I was thinking about 18" and a DVI. I also want it to be HD if possible so a res of 1680x1050.
The reason i am asking for help is i cant go over £80 on each monitor so i was wondering if there are any out there that would do the job for a great price.
Thanks
Jeremy
Keep and eye out they usually crop up, I bet there will be some within the week.
15" is just way too small and 4:3 is bad for eyefinity as your center view becomes really narrow and the bezels are too close. 16:10 is the best aspect ratio as 16:9 gives you a really stupidly wide eyefinity and not enough vertical resolution.
If you're buying 3 monitors with no DisplayPort connection then you'll have to factor in the cost of an active (mini)DisplayPort to DVI adapter at ~£25 unless you have something like a Sapphire FLEX graphics card.
