need help getting a stable overclock on a i5 760 and a msi p55 gd80 mobo
22 Nov 2010
Kettering
hey guys,
ive been using msi OC geine for some time now and have decided to learn and overclock the proper way :)
now iv watched some vids on youtube of my cpu and mobo being overclocked, ive tried doing it and i dont think i have done it right lol
ive put the QPI to the lowest it would go (16)
raised the cpu v to 1.400v
DRAM v to 1.650
put the cpu base frequency to 185
cpu ratio at 21 (it wont let me change it)
have i dont it right or have i done is completely wrong ?
tbh it wont surprise me if i have as it is my first ever time :)
rite, ive changed a few settings now
hows this look ?
core voltage - 1.25v
core speed - 4ghz
multiplier - x21.0 (wont let me change it at all in bios :( )
bus speed - 190.5mhz
QPI link - 3048.3mhz
DRAM frequency - 762.1mhz
9-9-9-24 timings
NB frequency 3048.2mhz
now all these readings are from CPU-Z, do they look ok or do i need to change something ?? remember guys this is my first time overclocking in the bios so please bare with me :)
i have also been running prime95 on the blend test at the highest temp i have is 77, average is about 71-74 :)
please someone help, i dont want to run bf3 then something bad happens, someone please advice and give the ok or tell me what needs changing :)
how high are you wanting to go?
you're not actually asking for specific help? You're only checking your stats. It'll be different for everyone. Mine runs at 3.8ghz 24/7 on a pants Mobo, but yours could run even higher with the right credentials.
Bottom line if you can run a stress test without fail then you're good to go, but just watch your temps whilst it runs.
For me, i'd take the ~70's temps and not worry about them
i want at least 4ghz out the cpu, its at 4ghz atm but i just want to check if the settings i have done are correct
on prime95 blend test the cpu peaks at 77 but mostly stays about 74
also sholdent the multiplier be 20 instead of 21 ? it wont let me change this
