need help getting cpu cooler?
23 May 2009
London
Hi guys i would like to upgrade my stock cpu cooler.
on an i5 760
and i was wondering which of the 2 are better.
im eiether looking at.
CORSAIR H60
or
ANTEC H20 620
i know there both roughly around the same price but what 1 is better
as i cant make my mind up and reviews are saying both are good or 1 is better then the other?
Help is much appreciated thank you :)
what case do you have? you may find that you can get something thats quieter with better cooling for less money than the H50/khuler 620, because the all in one watercoolers are quite expensive for their performance.
however, if you plan to move the PC quite a bit, then the watercoolers are the way to go.
if you do hae to go for a water cooler, i would go for the antec 620, as it seems to be ever so slightly better in performance and noise:
corsair H60 benchmark
antec khuler 620 benchmark
however, if you arent planning on moving the computer around a lot, let us know what case you have, and what RAM you have, then i can recommend you an air cooler that is almost certainly better than both of those
my pc is just in 1 place if thats wat u mean i dont swap and change things often eiether.
erm my case was like 30 pounds its a thermal take nothing special
in that case you will probably be better off with a decent air cooler instead.
for the same price as the antec 620 and the corsair H60 you can get a thermalright silver arrow, which, if it fits in your case, is a far better cooler than either of those watercooled options:
thermalright benchmark
its a touch quieter than the antec, while being 6C colder
however, i'm going to need to know what model thermaltake case you have before i suggest using it, because its quite big (163mm tall)
