Need help Fitting HID's Quick before it gets dark! 56K
As some of you might rember i got a set of hid's but it was the wrong type as i needed the ones with two bulbs so i could have hi and full beam!
Now i got the bulbs i needed today but i dont know how to fit them! help
Here is the bulb with a HID and a normal bulb for full beam
The bulb has these connectors on
As far as i can see the two and the left goto the ballest and the red and black goto the cars headlamp plug... but all the red and black do is put the normal bulb on with no hid!!
Now on the ballest we have these plugs!
So when connected up the white plug on the left dont do anything (im sure they all pluged in on the last set)
Finally here is the plug on the car.
I dont understand how to make the HIDS work! any help?
Cheers
Cheers
