Need Help Guys Sourcing Stuff
7 Nov 2006
Stockton on Tees
I need your help guys.
The items are strictly not AV but they will be used in an AV environement.
First Item:
Im after some laminate flooring which is WHITE (a dull'ish white) which resembles floorboards.
B&Q dont have any and nor do Next.
Second Item:
Im after LAQUERED HIGH GLOSS side table which is a BLOCK. Something like this: http://dwell.co.uk/104172
but i need it in a smaller size (400mm x 400mm x x 400mm).
I dont think there is anwhere which sells it in that size so will be looking at getting it made. Does anyone know of a place which can build these to size???
Any help would be appreciated.
First Item:
Second Item:
Do the dimensions have to be exact?
http://www.amode.co.uk/coffee-tables/high-gloss-storage-cube-side-table-with-castors.html
