Hi I bought a broken 7990 off eBay as it was cheap and i enjoy trying to fix things, as the unit is brand new I couldn't let it go (no idea why the seller couldn't RMA it)
Anyway when it arrived I had a good look at it and it seems one of the smd capacitors has been knocked off the back of the GPU. I am having great difficulty identifying the correct capacitor as I don't have it to test it.
I have removed one of the other capacitors within the area and tested that which is 20uf but I don't know the correct voltage for it. I was hoping as you guys seem to be pulling your PC's apart like me you may have a broken one that you could test or know of a place that has circuit diagram etc. Any help would be appreciated. If nobody can help I will order what I think will work and post back results in case somebody else has this problem.
Here are some pictures
