Need help identifying components from a diagram
zYx
zYx
2 Dec 2007
ISS
Hello,
I just have question.
What mean 10K - 10K marks on the diagram below?
Resistors?
According to the picture below, these don't look like resistors to me or am I missing something?
This diagram shows how to build a ground loom isolator for car audio. I'm not entirely sure what components I need according to the above.
If someone could guide me to maplin for the corrects parts I would be grateful.
Cheers.
ref datasheet
http://www.mouser.com/catalog/specsheets/XC-600134.pdf
you are looking at schematic A, 6 pins
your diagram is missing two dots to identify the start of winding, so assume at dot at the top, on both sides
so on LHS, input into pin 1, ground on pin 3
on RHS, output on pin 4, ground on pin 6
I'd double check this with Dr Em, it's his area really :)
Shame the estimated delivery is February 2013 :(
Ah, awkward.
I was looking on ebay for equivalents but there is nothing really, just a bunch of 600ohm line transformers and almost no 1:1 types.
Frequency response quoted is a bit poor for some of them too, something to keep an eye on when looking for equivalents.
Ask around on the DIY audio forums, someone may have already researched something similar :)
Apparently, this is what I need and this one being the cheapest with 3.5mm jack.
