Need help in building new pc
22 Aug 2009
Nottingham
Am looking to be running trifire 5870 in my next build. so looking for a hole new pc set up
At the mo ive got three asus 5870 gpu and i wont to base my spec around the new Asus Rampage III Extreme. Can anyone give my some advice on the other components that will give my trifire room to shine.
Also i think i would be needed to sell my enermax galaxy 1000w because ive only got two gpu outputs.
Do you absolutely need that kind of processing power?
Or do you just have a shed load of money you dont want, if so Ill have some - so I can upgrade from my 12yr old PC >_>
I swoped a old motor bike for the 3rd 5870. b ought the other two off ocuk.. so thats why am looking to use it in trifire
and anyway i dont drink or smoke and ive worked really hard for the money ive saved. People spend sheds loads of money on stupid things. but this is my hobby.
