Hi all, I'm in need of some help or ideas on what I can do.
My system:- Bought at Overclockers May 09.
Ultima Eliminator OC Intel Core i7 920 2.66GHz @ 4.00GHz
GTX 295 1792Mb DDR3, 12GB RAM, Motherboard GA-EX58-UD5, Win 7 Ultimate 64Bit
Problem:-
A few days ago I had a couple of screen freezes with the GTX 295 so updated the drivers to the latest drivers 266 I think. As I use a Sony Bravia 37" as a monitor I can't see any boot up screens until windows loads. Last night I had a screen freeze and decided to re-boot but the system didn't complete the operation. As it was getting late I knocked it off to do later.
Today I plugged in a Philips 19" to observe the boot up, at first the initial screen had dashed lines but as the BIOS screen kicked in it was a mass of symbols and totally unreadable, it would get to window loading screen and then stop and hang. (corrupted BIOS)
I re-booted the system and it got worse as now there is no BIOS screen at all.
On POST there are no beeps to indicate anything is wrong so I am assuming the CPU, RAM and video card are working as they should be but can't be sure. Motherboard GA-EX58-UD5 has a 26 showing in lights.
From manual
26h 1. If Early_Init_Onboard_Generator is not defined Onboard clock generator initialization. Disable respective clock resource to empty PCI & DIMM slots
2. Init onboard PWM
3. Init onboard H/W monitor devices.
After asking support via OC website, they said take CMOS battery out as below
I took the CMOS battery out of the machine for 15 mins (cables disconnected etc) as instructed but alas to no avail.
I can't see the BIOS to change to onboard, I can't flash the BIOS as I can't access the BIOS screen (F8 QFlash).
There are no burn marks, smell to suggest faulty boards/frying etc, all fans whirl away as normal.
Graphic card, I can't tell if it is working as there is nothing on screen and haven't a spare machine to put it into to test. All cables fitted and secure.
I thought I would ask here to see if anybody had any ideas, I am a qualified CompTIA A+ but I'm obviously having a brain fart/bad day as my logic gives me only two routes.
Graphics card or Motherboard, but I could buy one and it could be the other or none at all and just wasting money.
To be honest I'm stumped and at a loss, hopefully some kind person out there will help out and provide an answer. Hopefully I have given enough infomation for you to get the picture.
Thanks in advance
Darrell
Problem:-
From manual
2. Init onboard PWM
Thanks in advance
Darrell
and check condition of RAM/CPU
