Hi there,
I have a STEELPAD 4D with the shiny side up. I put cellotape to see if it would run smoother but there was no difference and it was very smooth at the start.
Now 1-2 days later it seems less smoother and if i look on the bottom of the mouse on the bits that contact the surface they look a little worn out (I've had this mouse for 1-3 months).
Is it something I should worry about? The mouse is not exactly quiet when it moves across the pad. Is there too much friction?
Thanks.
Thanks.
