- 28 Jul 2007
Hey, I am currently running a Shuttle SS21T with the following spec:
Intel P4 3.2ghz
1024mb DDR2 Ram
160gb Maxtor HD
Nvidia Geforce 7300 GPU, 512mb
I was looking to upgrade my GPU, when i discovered that my power supply was only 250W, and i was told this would not be enough to run anything above the 7300 i am using now. On top of this, i cannot upgrade my powersupply, because of the nanobtx form factor (I dont believe you can use conventional ATX PSUs). Can anyone see a way around this other than buying a whole new barebone??
Any help/advice would be appricated! Thanks
Intel P4 3.2ghz
1024mb DDR2 Ram
160gb Maxtor HD
