Need Help. Networking Laptop with PC
7 Nov 2006
Stockton on Tees
Hi Guys
My brother brought a laptop yesterday, the Dell Inspiron 6400, which has wireless intergrated. How could i network his laptop to my pc?
My pc is upstairs in my bedroom and has got broadband. The laptop will stay downstairs so i need to network them both together so that he can share my broadband connection aswell as some folders/drives which i give him access to, and file transfering from one to the other.
Any suggestions guys?
Ideally under £100 but can push it to £150
Thanks
pukeater™ said:
Wireless setup would be best. Get a Wireless router (Either a cable one or a Dsl one). Should be quite straight forward to set up. Follow instructions with Router.
any good suggetsions for a good quality wireless router? Looking for a complaete package where i dont need to be a router and then seperate cards. Ideally under or £150
bearing in mind the range needs to be good and capable of good speeds as the laptop will be downstairs and main pc upstairs.
kbc said:
Get yourself a Linksys WRT54G (Wireless Router Only). Plug the cable modem using the ethernet cable into the WAN port of the Linksys.
Connect yourself up using one of the 4-ports on the Linksys (if you wish to use wired) and then just configure the wireless on your brother's laptop.
Works fine on NTL.
That only has 54Mbps and drops to 11Mbps when transfering files.
Can you recommend any 200/300Mbps ones....?
how about Linksys WRT300N-UK Wireless-N Broadband Router/4-Port Switch"
