Hi, can anyone help? I've just rebuilt my comp a week ago, and these are my new components-
Asus M2N32 WS Pro nForce 590 SLi (Socket AM2) PCI-Express DDR2 Motherboard
AMD Athlon 64 X2 Dual Core 5200+ 2.60GHz (Socket AM2)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
Asus GeForce 8600 GT 256MB GDDR3 HDTV/Dual DVI (PCI-Express)l
After I put this all together I expected great performance, but have experienced everything else, but what I expected. I can not play any of my games, because after cca 1 hour of playing the game will freeze, and I need to reset the system. Well, I've tried to reinstall the Windows, but the results were the same. I thought it was the power supply (I have an Antec case, and the p.s. is stock 380W), but yesterday my comp froze after an hour of playing a movie, which should be no problem (and was, untill yesterday) for it. Well, that was it for me, can not think of anything else what should be the problem, so the question is : Should I throw it out the window (what I almost did yesterday), or is it something else (as it usualy is, some stupid thing, like some cable not plugged correctly, or BIOS settings...)? Anyone have an idea?? I'm pretty desperate. Thanx a lot.
dont laugh i have friend who forgot lol.
