need help oc GA-Z77X-UD3H
9 Jun 2011
UK
as the title says,my asus sabertooth died on us a few days ago and i was told it going to take up to 3-4 weeks for a replacement from asus??
anyway cut the story short i had to go with a gigabyte ga-z77x-ud3h as a stand by but am total new to gigabyte boards and looking at this the bios as loads more bits than the asus which was easy to oc,so if anyone could help us oc this board i be grateful . need to do a manual oc prob to 4.5. set up as in sig apart from the motherboard
thx in advance
How much CPU v was needed for 4.5ghz on your last board? Just set CPU voltage response to fast,pwm phase control to extreme,CPU multi to 45,CPU voltage to normal,dvid which was offset on asus to +0.010v llc level to high and see how it does
For a fixed CPU voltage just set CPU v to that amount and leave dvid
thx wazza but am going to act a dumb on this as i always used an asus and the layout on this gigabyte is total different to the asus where as eberything is a drop down box.
would be nice if anyone have got any saved bios pics to go by
