- 6 Feb 2008
Going through an OCR June 2007 core 2 past papaer
On Q7.
a) In an arithmetic progression, the first term is 12 and the sum of the first 70 terms is 12915. Find the common difference/
12=a 12915= total 70 term
12915= 70/2(24+(70-1)d)
12915=35(24+69d)
12915=840+2415d
12075=2415d
d=5
b) In a geometric progression, the second term is -4 and the sum infinity is 9. Find the Common ratio
~<<<<<infinity
ar= -4
then i know i have to put it into the equation s~=a/1-r
9=-4/1-r I am guessing you some how get two sets of brackets that will give you value of r
I don't really know where to go from here so if someone could explain the steps to me then i would be very grateful
Thanks
On Q7.
12915=35(24+69d)
12915=840+2415d
12075=2415d
d=5
~<<<<<infinity
ar= -4
Thanks
