Need Help on building a pc. (around £600-£700)
7 Dec 2009
I plan on building a new pc (for gaming and Collegework/ Programming), but its been a while and i am unsure of compatibility of RAM and motherboards etc, i just wondered if i had made and monumentally stupid mistakes in selecting these components.
Processor: AMD Phenom II X4 Quad Core 965 Black Edition* 3.4Ghz Quad 146.99 http://www.overclockers.co.uk/showproduct.php?prodid=CP-253-AM
RAM: Patriot Viper 4gb (2x2) 88.99 http://www.overclockers.co.uk/showproduct.php?prodid=MY-019-PA&groupid=701&catid=8&subcat=1516
MotherBoard: Asus M4A785TD-V Evo AMD 785G 74.99 http://www.overclockers.co.uk/showproduct.php?prodid=MB-355-AS
HDD: Seagate Barracuda 7200.12 500Gb 39.99 http://www.overclockers.co.uk/showproduct.php?prodid=HD-206-SE
PSU: OCZ ModXStream Pro 500w 56.99 http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-OC&groupid=701&catid=123&subcat=
CD/DVD Drive: LG GH22NS50 22x DVD±RW SATA ReWrite 22x 18.99 http://www.overclockers.co.uk/showproduct.php?prodid=CD-094-LG&groupid=701&catid=10&subcat=
Graphics: Sapphire ATI Radeon HD 5770 1024MB 115.98 http://www.overclockers.co.uk/showproduct.php?prodid=GX-216-SP&tool=3
Case: NZXT M59 Mid-Tower Windowed Case - Black ATX 46.99 http://www.overclockers.co.uk/showproduct.php?prodid=CA-020-NX&groupid=701&catid=7&subcat=
Im also wondering if it would be worth spending £60 extra on a HD5830 instead of a HD5770.
XFX ATI Radeon HD 5830* http://www.overclockers.co.uk/showproduct.php?prodid=GX-168-XF&groupid=701&catid=56&subcat=1711 174.99
Thanks In advance for any advice you may have.
This is what I would get:
AMD Phenom II X4 955BE ~ £128
http://www.overclockers.co.uk/showproduct.php?prodid=CP-244-AM
Asus M4A89GTD PRO ~ £108
http://www.overclockers.co.uk/showproduct.php?prodid=MB-392-AS&groupid=701&catid=5&subcat=1782
Has a split 8+2 phase VRM with cooling,6 SATA 3.0 ports, all solid capacitors and does symmetrical Crossfire at PCI-E 2.0 8X/8X. Uses the SB850 southbridge.
OR
Asus M4A79XTD Evo ~ £90
http://www.overclockers.co.uk/showproduct.php?prodid=MB-366-AS&groupid=701&catid=5&subcat=1481
Has a split 8+2 phase VRM with cooling,all solid capacitors and does symmetrical Crossfire at PCI-E 2.0 8X/8X. Uses the SB750 southbridge.
4GB low latency 1600MHZ DDR3 ~ £90
http://www.overclockers.co.uk/showproduct.php?prodid=MY-180-OC&groupid=701&catid=8&subcat=1517
HD5770 1GB ~ £116
Zalman Z7 Plus Midi Tower Case ~ £43
http://www.overclockers.co.uk/showproduct.php?prodid=CA-033-ZA
Samsung F3 1TB ~ £58
http://www.overclockers.co.uk/showproduct.php?prodid=HD-082-SA
Pioneer SATA DVD rewriter ~ £19
http://www.overclockers.co.uk/showproduct.php?prodid=HD-006-IN
Antec TruePower New Modular 650W Power Supply ~ £77
http://www.overclockers.co.uk/showproduct.php?prodid=CA-117-AN
The Antec PSU I have listed is made by Seasonic and is a better unit than the current OCZ ones at a similar price IMHO. There is also the cheaper 550W version for around £70.
A pair of HD5770 1GB cards can be as fast as an HD5870 1GB.
The total comes to around £621 to £639 excluding delivery.
You could add an SSD such as the following if required:
I assume you have a copy of an OS.
Considering the price of the 5830 has gone down to a more sensible price now I think its worth getting :)
I also agree with the OCZ RAM its a much better manufacture. Also change the HDD to a Samsung F3 Spinpoint for the same price :)
Thanks for the advice !, so would i be better off buying a 5830, or getting one 5770 now, and then in a couple of months (When funds are adequate) to get another one and run two?
either go all out and buy a 5850, or buy one 5770 now and another later.
5830=sucks, still to much money, even at £160.
Thanks, this has helped a lot, one last question, the two mother boards listed Bellow,
http://www.overclockers.co.uk/showpr...=5&subcat=1782
OR
http://www.overclockers.co.uk/showpr...=5&subcat=1481
Is there a major difference between them, and is it worth spending £20 more for the £108 One ?
i7 build?
This is a conglomeration of whats been suggested across a few forums:
AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz (Socket AM3) - Retail
£127.98
Sapphire ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card
£115.98
Asus M4A79XTD Evo (Socket AM3) DDR3 Motherboard
£89.99
OCZ Gold Low Voltage 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3G1600lV4GK)
£89.98
OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-031-OC
£63.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)
£57.97
Zalman Z7 Plus Midi Tower Case - Black
£42.99
Pioneer DVR-S18L 22x DVD±RW SATA Labelflash ReWriter - Black (Retail)
http://www.overclockers.co.uk/showproduct.php?prodid=CD-069-PO
£18.99
£608 Excluding delivery
+ windows 7 pro £70
Unless i have done something really stupid (I'm fairly paranoid about things being incompatible etc.) but this is what i'm edging toward.
Excellent!, thanks everyone, one final thing, i dont need to buy screws or cpu heatsinks etc , do i? they all come with the components ? and all i need i have included above?
screws come with the case.
heatsink is in the cpu box, with thermal paste already applied.
sata cables come in the motherboard box
