Need help on buying graphics card
3 Aug 2017
Hi, I'm hoping someone could help me out here.
I'm in need of a graphics card but I'm not sure which one to get. Could you recommend a decent one that is compatible with my PC.
I have a Gigabyte GA-F2A68HM-HD2 motherboard.
Any help will be greatly appreciated as I'm a complete noob when it comes to computers.
Thanks. :)
Thanks. :)
It all depends on your budget.. gfx cards start at £50ish and the sky is the limit
As above, budget, which monitor (Gsync/Freesync/nosync/refresh rate, resolution) and what type of games you play (modern AAA games or older ones). Some cases can't fit really long video cards either, so check the max GPU length for yours.
And welcome to the forum.
Given that you are running, at best, an Athlon 860K or an A10, you will bottleneck the snot out of any serious videocard out there. Get a GTX 1050, at best. Anything else will be crippled by your CPU.
