Need help on choosing NAS
26 Dec 2013
404 Not Found
I am trying to figure which NAS would best suit me. Here are the two that have caught my eye at the moment.
NetGear 104
Synology DS215j
At the moment, I am going to be the only person access it, but may go up to 3 people in the future. The file sizes I work with are around 100mb. The ability to make a backup to a connected USB drive and to an offsite location over FTP at scheduled times.
I do like the look of the Synology, but the 4 bays on the netgear could become useful for the future.
I doubt they use much more power than a normal NAS tbh. Well worth looking into & would be quicker than a NAS of the same price i reckon
Reminds me..I'm still rocking desktop grade disks. Need to work out how to switch in some reds one at a time into the RAID.
Don't forget to automate a backup to AWS. So cheap to store data in there you're a fool not to. Expensive to get it out of course.
I looked into Glacier / AWS once, but the cost to get all my data out in case of disaster was ridiculous, a couple of hundred £ or something stupid.
Go for CrashPlan instead, especially if you're running FreeNAS. You can run it on there and configure/monitor from your desktop quite easily. Only £3 a month and it's unlimited. I have about 500GB on there now and a guy at work has around a TB without a problem.
I've got a Synology DS1515 at home with WD Red 2TB Drives in. Used for storing media for XBMC, can't fault it!
The Synology boxes run a torrent + usenet client if you're into that kind of stuff, and you can also get them to do remote access and numerous other things :)
