Hi,
I bought a whole PC in component form from OcUK at the beginning of 2007 which has always been stable but in the last few months it'll crash out of games like any HL2 based engine game, TF2 etc and things like COD:WAW. I've tried re-installing the OS without success. I'm sure it's probably driver related in some way, but i'm using the latest ones available. I suspect the sound driver, but the latest one on the Asus site is from the beginning of 2007
Anyway, because of this and the release of Windows 7, I thought it's time for an upgrade. The previous setup cost about £1400 and I want to try and use some of the things from the old PC to keep the cost down this time round.
My current spec is an Asus Striker Extreme, E6600, 4GB (4x1GB) Corsair Dominator PC2-8500 DDR2, 2 x 8800GTX, (one BFG stock card and one XFX XXX Edition), a Samsung 1TB HDD, a Pioneer 20x DVD-RW and an Enermax Galaxy 1000W in a Antec P160 windowed case running Vista Ultimate x32 with SP2.
I've been trying to work out the best upgrade that'll keep the price down but will still make the upgrade noticeable and worthwhile. I'm considering the following:
A Gigabyte GA-P55-UD6 or Asus Maximus III Formula motherboard, a Core i7 860 CPU, haven't got a clue on which memory
, an ATI 5870 card and then run it on Windows 7 Home Premium preferably x64 if it'll work with games, but x32 if not.
The reason for looking at the 5870 is that there's no DX11 Nvidia card available and I would probably keep my 8800GTXs if I could get them to work together. I've never been able to get them running in SLi without games crashing within a few minutes. I bought the XXX Edition as a second card when OcUK had a special deal on them a while back. I'd read that mixing OC'd and non OC'd cards were ok as the speed of the OC'd card would drop to match, but in my system, it does the reverse and tries to overclock the BFG stock card to XXX speed, (I checked with the Nvidia monitor) and this happens even if I change the slots the cards are in. Adjusting them manually doesn't help, it'll still be unstable in SLi.
So, I looked at the newer i7 rather than the 920 which I originally had my eye on because it's a newer chipset and I read a review that said the 860 will outperform some of the higher end 9 series chips making the original i7s potentially dead. Does anyone agree?
Also, as the 5870s are so difficult to get hold of with the shortage, should I just get a GTX285 or GTX295 which will give me similar performance to my 8800GTXs, (if they worked
) and not worry about DX11?
The reason for the rush is I'm a bit impatient
and I'm on holiday this week, so I'll have the time to completely rebuild and re-install the system.
Any suggestions on whether this is the right move or not or if there's a better way of utilising what I've got would be very, very much appreciated!!
Thanks!!
Thanks!!
