Need help on this...
14 Nov 2005
ok. my spare machine is running an athlon 64+ 3500, nForce 4 mainboard, 2GB of RAM (PC 3200).
Basically, all the games i run on it..are extremely glitchy, slow and freeze up a lot and the texture are all not properly rendered and extremly blurry/glitchy.
ive tried rolling back to older gfx drivers but that didnt seem to solve the problem. ive also ran 3D mark and the same happens on there as does with the games.
I'm sure its not a heat problem...got the case open and cpu temp is about 38c under load. I dont wanna say the board/or gfx card is fudged as its a bit too soon. any ideas?
What is the graphics card and what are it's temperatures like? Have you run any tests such as Memtest or Prime95(for the CPU)? Have you tried reseating the graphics card and Ram? Sorry if these are obvious but sometimes it pays to get these things out of the way initially.
