Need help on which Powerline Adapter would be best
18 Aug 2010
Scotland
I have already looked around the net, but the reviews are really mixed which is why I am looking here for some help. The 2 adapters needed will be for hooking up a laptop at the other end of the flat where the wifi is poor, so would rather have a direct hookup to the adapter, so looking for any advice as to which pair of adapters would be best (max. price for the pair £45 and wifi is not needed)?
TY in advance
I use the TP Link Nano 500's, they seem as reliable as the other's I've used over the last decade and are inexpensive used and still fall in budget new.
Beware anything under gigabit speed will come with 100mbit ports and limit you to 12.5MB/s max anyway, if you have lower than 100mbit WAN then it's not an issue.
