Need help on which processor to get
29 May 2005
I'm looking at getting a new pre-built system but am getting a little confused as to which processor is best for me.
I've seen 4 pc's with pretty much exactly the same spec apart from the processor. The basics they all have is 6gb ram, 1gb graphics card, 1tb 7200 hard drive, windows 7 home prem 64bit
The prices are all in the region of £700ish.
The 4 processors in question are
1) Intel® Core™ i5 Processor 650 (3.20GHz, 4MB)
2) Intel® Core™ i5 Processor 760 (2.8GHz,4MB)
3) AMD® Phenom™ II X4 830 (2.8GHz, 6MB Cache)
4) AMD Phenom™ II X6 processor 1035T (2.6 GHz )
I know there's the whole number of cores thats the issue with each of them, but im not sure what is best for me.
Im not a big time gamer though i like the odd one now and again. Its mainly to be used for normal pc use and as a media hub.
Any help is very much appreciated.
Thanks in advance, and Happy New Year to you all.
Jay
None of those should come with 6 gigs of ram as they should all use dual channel ram which would be 4 or 8 gigs. 1gb graphics card is very vague as it could be any number of models ranging from good to flat out trash. The 1 gig of ram part doesn't help much if the GPU part is crap. Its like saying "muscle car with a 4 barrel carb" but the actual car is a VW compact with a 1 liter engine:)
Kinda need to know the rest of the specs. If they are all around the same price then the rest of the kit they come with is not going to be the same.
ok, sorry if thats been a bit vague, its just they are from different sites and didnt want to cause any offence. Here the specs for each of them in more detail.
1) PROCESSOR Intel® Core™ i5 Processor 650 (3.20GHz, 4MB) edit
OPERATING SYSTEM Genuine Windows® 7 Home Premium 64bit- English
OPTICAL DRIVE DVD +/- RW Drive (read/write CD & DVD) with Roxio Easy CD and DVD Burn software edit
MEMORY 8192MB (2x4GB) 1333MHz DDR3 Dual Channel Memory
HARD DRIVE 1.5TB (7,200rpm) Serial ATA Hard Drive
GRAPHICS CARD Graphics Card - Single 1GB Nvidia GeForce GTS 240
SOUND SOFTWARE Integrated HDA 7.1 Dolby Digital Audio
2) PROCESSOR Intel® Core™ i5 Processor 760 (2.8GHz,4MB) edit
MEMORY 8192MB (2x4GB) 1333MHz DDR3 Dual Channel Memory edit
HARD DRIVE 1.5TB (7,200rpm) Serial ATA Hard Drive edit
3) * AMD Phenom™ II X4 830 (2.8GHz, 6MB Cache)
* Genuine Windows® 7 Home Premium, 64bit, English
* 8192MB Dual Channel DDR3 [4x2048] Memory
* 1TB (7200rpm) SATA Hard Drive
* Blu-Ray ROM Drive (read/write CD/DVD & read Blu-Ray Disc)
* ATI Radeon™ HD 5450 1GB DDR3 graphics
4) Genuine Windows® 7 Home Premium 64-bit
AMD Phenom™ II X6 processor 1035T 2.6 GHz Chipset AMD 760G
6 GB DDR3
4 DIMM sockets
1 TB SATA 3G Hard Disk Drive (7200 rpm)
DVD writer SATA DVD RAM and Double Layer supporting LightScribe technology
ATI Radeon™ HD 5450 with Avivo technology
up to 3839 MB total available graphics memory, with 1 GB dedicated
Display
DVI port; VGA port; HDMI port
I hope thats more clear.
Thanks
i'd assume the phenom x6 would last longer than any of the rest, espeically if you dont game a great deal.?
