need help overclocking new pc
27 Aug 2006
hello this is my spec:
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz
Connect3D ATI Radeon X1950 XT-X SILENT Heatpipe 512MB GDDR4 AVIVO TV-Out/Dual DVI (PCI-Express)
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache
Arctic Cooling Freezer 7 Pro CPU Cooler
Lian-Li PC V1000 PLUS Black Aluminium Midi-Tower
Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU
i desperately want to overclock this setup and get it running sweet but i havent got a clue about overclocking ... no matter how many times i read the posts and stuff it just wont sink in .. :mad: :mad:
so could i please have your help
even if you just post the progs that i need that will be enough and ill figure it out myself.. pls help me with this
many thanx in advance
Dude, not to be rude at all, in any way, but if overclocking won't sink in then I really would not try doing it yourself. It's just like climbing a tree: we can help you climb but when you want to come down and we're not there...?
If you run in to a problem when overclocking and - for some reason - your computer doesn't post or even turn on, how will you know what to do without posting on here? How will you know what caused to the problem and how to resolve it?
Trust me - overclocking is something you need to do yourself to do it properly. Hardware in this day and age has come a very long way to help the average joe/sharon overclocking his/her computer because of the multiple levels of safety built in to them, making it very difficult to break stuff outright. However, that doesn't mean that anybody should have a go, in my opinion.
ok dude no probs ill just have to try harder to understand the concept of overclocking .. i just need to set ram up and gfx card because i think they are under achieving their full potential.also i think my ram is set to 5-5-5-15 aswell i did set it to 4-4-4-12 in the bios and put the voltz up to 2.1 but i changed it back because i dident feel confident in what i had done just incase i missed somthing. thanx anyway for help.
p.s: mrthingyx no you wernt being rude what you said was constructive :)
Print off as much infomation as possible about your hardware especially motherboard details regarding overclocking, check compatability problems as well including ram voltage settings, cpu voltage etc. Dont be put off overclocking, everyones different not everything sticks in the head just like that - make lots of notes to look back on if your system doesnt boot up etc.
