All,
Where can I get support for a machine built by the team of Overclockers? I cannot reach the support on the phone and I am really blocked, I want if needed to ship the hardware back for troubleshoot.
Without any change of the system, nor any move of it; the PC has suddently started to stop working properly.
On power ON, the system starts to run the fans and apparently power ON the motherboard etc. but then immediately stops after 5 or 6s second and tries to restart but stops in the same way. Unless I push the complete power to OFF, it will carry on for ever.
This is before anything is displayed to the screen, as if it was either a power shortage or a false contact somewhere.
I checked every component and everything is plugged correctly.
I unplugged one disk (power and cable), then the other one (two disk in Raid), thinking that would reduce the need of power but that did not change anything.
Actually even if the 2 disks are unplugged the same problem occurs.
So I believe there must be a component faulty that prevents the starts, this seems to be related to electric power like a protection fuse
I cannot do anything and really need the pc to work, any input is very welcome!!!
Regards
Raphael
Support Details:
Motherboard: Abit IP35 Pro
Motherboard Driver:
Motherboard Chipset: Intel
Motherboard BIOS:
CPU: Core 2 Quad Pro Q6600
Memory: 8Gb OCZ
Memory Latency:
PSU: OCZ ModXStream 900w
Graphics:
Graphics Driver:
Sound Card:
Sound Driver:
Operating system:
Changes prior to problem: none
Regards
Raphael
Support Details:
Motherboard Driver:
Motherboard BIOS:
Memory: 8Gb OCZ
Memory Latency:
Graphics:
Graphics Driver:
Sound Card:
Sound Driver:
Operating system:
