So a few months ago when playing games on my PC, the fans or something would begin going into overdrive sounding like a jet engine for like 5 seconds, this would occur at least a few times every minute or 2. It would also get ridiculously hot and it began overheating and taking me to the BIOS screen. I took it to a maintenance shop and they fixed the water cooling and gave it a clean. Now the frames on every game I play are terrible, I can only play very old games or a select few, most games are basically unplayable especially FPS games as I get bad stutters when I flick. It doesn’t overheat mid session anymore but if I play for a while then restart my PC the BIOS screen will again come up saying the CPU is overheated.
I’m looking to buy whatever part I need to fix this issue but I’m unsure if this could be the GPU, CPU or something else, could really use some help and if any more info is needed I’ll try my best.
