Hey Guys,
I bought and built my pc 2 months ago wasn't really any problems for the first month or so.
It suddenly would randomly just freeze and then i would have to reset it then it would be fine again.
Last night it did the same and now the power boots up and then it cuts out after approximately 30 seconds (with no display coming up either).
Ive tried taking out 4 of the 8 gig worth of ram and using the other 4 and makes no difference.
If it helps my Spec is:
AMD x6 1090T
Asus Crosshair IV Mobo
8GB Dominator 1600 Mhz
HD5970
1200W Coolermaster Silent Pro
OCZ Vertex 2E 120GB
2x Samsung F4 2TB
Megahalems and 1x Asaka Viper fan (did have 2 but decided to take 1 off as i havent had the need to OC my cpu.)
Any help would be much appreciated.
Thanks
Mehmet
AMD x6 1090T
HD5970
OCZ Vertex 2E 120GB
2x Samsung F4 2TB
Thanks
Mehmet
