Need help picking a new laptop
26 Dec 2014
Hey, I've recently sold my MacBook Pro 2009 and am now looking for my next laptop. I've been searching for a while but there are so many to choice from.
The main features I want the laptop to include are:
Decent ability with working with music (I produce music in Fl studio and my old mac just couldn't keep up)
Can handle gaming okay
Nice build quality (not that cheap tacky plastic stuff)
Backlit keyboard, whilst not completely needed it's always been a nice feature I like to have so I can work in crappy lit places
No screen size less than 15.6"
Portable :P
And the last I thought I should mention is my budget.
I have around £500-600 / $780- $930 to spend and I also don't mind buying a used laptop
Thanks in advance,
Ryan
Lenovo Y500/510p 2nd hand. Y500 has a GT650m/750m and the Y510 has GT750m both of which support SLI with an additional card via ultrabay.
My 500 o/c to 1150mhz GPU SLI and plays anything that's thrown at it high/ultra re gaming.
Only budget a SSD drive as the 1TB that comes with them both is slow unless it has the 16GB SSD boot paralell with the 1TB
There are a few on the bay, however a lot seem to be USA sourced.
Thanks for the response, the Y500 has been among the huge list I've been watching, haha. I will check out the others also.
I've also seen a lot of Lenovo with the AMD A10, any idea how that compares to the i5 or i7?
"Nice build quality (not that cheap tacky plastic stuff)"
Unless they've drastically improved things since the T500 then you definitely don't want a Lenovo if you don't want "cheap tacky plastic stuff". The plastics on this are absolutely horrid with some rough/sharp edges. On the plus side it has been 100% reliable.
Hmmm, okay. So what do you recommend getting?
The T500 is from 2008 and it's a business ThinkPad. The entire point is that they're indestructible in normal use, and look like a monolith. Quite a lot of the cheap tacky plastic is magnesium alloy! ;)
