I'm planing a new build with a i5-4690K on a Z97 Extreme4 motherboard. I'm using a ATCS 840 case so lots of room. I have 2x Noctua 120mm quote fans spare to mount on it. I will be doing some overclocking.
Ideally it needs to be able to mount both my 120mm fans. (need it quite!).
I'm not sure about ram hight clearance on the motherboard (not ordered yet).
Budget is around £40 but can go more if there's good reasons.
