need help please
22 Mar 2006
i have put my new rig together and it all seems to be in the right place but when i boot up i get nothing from the monitor, the light on the motherboard is green and all fans are working.
i dont get any sound also.
not sure what to do, any suggestion would be great
Danny
MO-012-AC Acer AL1916W 19" Widescreen LCD Monitor - Black/Silver (MO-012-AC) 1
£149.95 £149.95
CP-152-AM AMD Athlon 64 X2 Dual Core 3800+ (Socket 939) - OEM (CP-152-AM) 1
£169.95 £169.95
MB-101-AS Asus A8N-SLi SE nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-101-AS) 1
£64.95 £64.95
MY-046-GL GeIL 2GB (2x1GB) PC3200 Value Dual Channel Kit CAS3 (GE2GB3200BDC) (MY-046-GL) 1
£89.95 £89.95
GX-018-BG BFG GeForce 7900 GT OC 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-018-BG) 1
£209.95 £209.95
FG-000-AR Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940) (FG-000-AR) 1
£12.95 £12.95
HD-046-WD Western Digital Caviar SE16 250GB 2500KS SATA-II 16MB Cache - OEM (HD-046-WD) 1
£55.95 £55.95
HD-002-MI Mitsumi FA 404M 7in1 USB 2.0 Floppy & Media Drive - Black (HD-002-MI) 1
£12.95 £12.95
KB-058-LG Logitech Cordless Optical Desktop Rechargeable Black/Silver - OEM (KB-058-LG) 1
£29.95 £29.95
CA-001-AR Arctic Cooling T2 Silentium Silent Midi Tower Case - 450W Seasonic Silent PSU (CA-001-AR)
Have you checked that you have all the power cables plugged in - 24pin to motherboard, 4/8pin to cpu, molex to motherboard for vga (only needed for sli but can help to have it plugged in), vga card power cable.
Also make sure vga card is pushed in firmly and that your monitor is set to the right input i.e if your using vga cable then its set to vga rather than dvi.
As for sound thats normal until you install the drivers
ok up and running now, the case is a little noisy considering it supposed to be a silent case, and the cpu temp is 40c and thats with a 64 freezer pro.
is this normal / ok?
Danny
