I've bought a i7 3770k as an upgrade for my system that is currently using a i5 3570k. When I installed the i7 and powered on the computer itself turns on but does not post to bios or and the monitor does not turn on. The computer itself is running as I can hear the HDD/ Fans moving.
I've tried using the integrated graphics hdmi/vga/dva and no signal at all.
I've also tried taking out all of the components and just leaving in 1 stick of ram with the cpu - flashing different bios/clearing CMOS and nothing seems to work.
When I install the i5 back in the computer boots fine and there are no problems at all, do you think the i7 CPU is dead?
Mobo GA Z77 D3H
Ram 16gb TridentX 2400mhz
r9 290 TriX
PSU Corsair CX600
Thanks
Mobo GA Z77 D3H
r9 290 TriX
PSU Corsair CX600
Thanks
