Need Help - Quadro P620 at Dual Monitors
18 Apr 2021
Hello!
Really need help here. Kind of urgent.
Question one: I searched the whole internet and I cannot find a clear answer. I would like to know if I am able to run dual monitors at 144hz 1080p, both of them, with the p620. On the specs it says 4k 60hz, but nothing says about 1080p hz.
Second question: What about if I use one 2560x1080 monitor on horizontal and a 1920x1080 on vertical, both at 144hz. Will it work at 144hz?
Still urgent?
I Googled that card, first real result after an ad, was on the PNY website. Scroll down that page and look for the link to NVIDIA Quadro and NVS Display Resolution Support. That PDF has a guide to resolutions and refresh rates. Doesn't mention 144, only 120, although this doesn't necessarily mean it can't do it. Depends on the connection you're using and your display device.​
Thank you! I had searched the nvidia website but didnt find it before. (Not english native also) Will look that up! I need to but this monitors asap and if the card does not support them I wouldnt want to pay the extra $.
thank you very much!
