Need Help! Ram install gone wrong
15 Jan 2009
Thailand ATM
I simply tried to add a piece of upgrade some ram, the new ram didnt boot. So I out the old one back in. Now when my pc tries to boot windows it crashes with a blue screen. Any ideas?
on your motherboard there will be a small battery you can remove for a few seconds that will reset the bios. there is often a small jumper you can move which will do the same thing.
Also make sure the ram is correctly and fully inserted and try another slot if needed
You may have. Is this a pre-built work pc, ie dell, HP etc? If you can take the hard drive from a similar model PC you could test that and rule out the os
must be, gonna wipe it now, most of the work in on a server so not too bad. Thanks for your help. Never seen anything like this b4, very random
If theres nothing you really need i generally just reimage work pcs as its so much quicker than trying to trouble shoot corrupt os or software.
