Well I finnaly got my watercooling installed and everythings going fine except from my GPU2 is getting very high tempretures even tho its the first thing the watercooling is going to?, is it proberly just the cooler on that card that needs reset? GPU1 maxes out at 30 C and the cpu maxes out at 40 C when stressing both at the same time with furmark and prime 95 but GPU 2 is going past 90 C
, GPU is the bottom one right? just want to make sure.
Also when I started up window time has changed at its at 9:45 when its 1.45 i think and its stopping a few programs from working properly so how do I fix this?
Big thanks to anyone that can help.
, GPU is the bottom one right? just want to make sure.Also when I started up window time has changed at its at 9:45 when its 1.45 i think and its stopping a few programs from working properly so how do I fix this?
i put the hose right through the block rather than one at eah side
